Zum Hauptinhalt wechseln
Crown Range Hood AFG-AC/SS Light Bulb Replacement
Was du brauchst
  1. Crown Range Hood AFG-AC/SS Light Bulb Replacement, Light Bulb: Schritt 1, Bild 1 von 1
    • Check to make sure the the range hood is off.
    • To turn the range hood off, press the highlighted button.
    • The range hood should not emit any light or make any noise.
  2. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 2, Bild 1 von 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips #00 to remove the single screw securing the lightbulb panel to the ceiling of the range.
    • Too prevent both of the items from falling, hold onto the screw and panel during removal.
  3. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 3, Bild 1 von 1
    • Slide the lightbulb cover out from the recessed area under the hood.
  4. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 4, Bild 1 von 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 4, Bild 2 von 2
    • Twist the light bulb left to remove it from the range hood.
  5. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 5, Bild 1 von 1
    • Use a cloth or a paper towel to clean the inside of the light bulb area.
    • Be sure to remove any debris or rust that might impair the installation of the new light bulb.
  6. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 6, Bild 1 von 1
    • Guide the new lightbulb to the middle of the lightbulb base.
    • Install the new lightbulb with a twisting motion to the right.
    • Ensure the lightbulb is tightly secured onto the lightbulb base but don't overtighten.
  7. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 7, Bild 1 von 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 7, Bild 2 von 2
    • Place the screw back into the light bulb cover.
  8. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 8, Bild 1 von 1
    • Set the light bulb cover back onto the light recess.
    • Use the Philips #00 screwdriver to tighten the single screw that holds the light bulb cover in place.
  9. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 9, Bild 1 von 1
    • Turn the light on to make sure your repair was successful!
Ziellinie
Ken Cantago
169 Reputation
1 Anleitung geschrieben
York University, Team M-7, Allen Winter 2023 Mitglied von York University, Team M-7, Allen Winter 2023
YORK-ALLEN-W23SMG7
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 24
Insgesamt: 434
