Zum Hauptinhalt wechseln
Crown Range Hood AFG-AC/SS Light Bulb Replacement
Was du brauchst
    1. Crown Range Hood AFG-AC/SS Light Bulb Replacement, Light Bulb: Schritt 1, Bild 1 von 1
      • Check to make sure the the range hood is off.
      • To turn the range hood off, press the highlighted button.
      • The range hood should not emit any light or make any noise.
      Frag FixBot
      Kommentar hinzufügen
    2. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 2, Bild 1 von 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 2, Bild 2 von 2
      • Use the Phillips #00 to remove the single screw securing the lightbulb panel to the ceiling of the range.
      • Too prevent both of the items from falling, hold onto the screw and panel during removal.
      Frag FixBot
    3. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 3, Bild 1 von 1
      • Slide the lightbulb cover out from the recessed area under the hood.
      Frag FixBot
    4. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 4, Bild 1 von 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 4, Bild 2 von 2
      • Twist the light bulb left to remove it from the range hood.
      Frag FixBot
    5. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 5, Bild 1 von 1
      • Use a cloth or a paper towel to clean the inside of the light bulb area.
      • Be sure to remove any debris or rust that might impair the installation of the new light bulb.
      Frag FixBot
    6. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 6, Bild 1 von 1
      • Guide the new lightbulb to the middle of the lightbulb base.
      • Install the new lightbulb with a twisting motion to the right.
      • Ensure the lightbulb is tightly secured onto the lightbulb base but don't overtighten.
      Frag FixBot
    7. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 7, Bild 1 von 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 7, Bild 2 von 2
      • Place the screw back into the light bulb cover.
      Frag FixBot
    8. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 8, Bild 1 von 1
      • Set the light bulb cover back onto the light recess.
      • Use the Philips #00 screwdriver to tighten the single screw that holds the light bulb cover in place.
      Frag FixBot
    9. Crown Range Hood AFG-AC/SS Light Bulb Replacement: Schritt 9, Bild 1 von 1
      • Turn the light on to make sure your repair was successful!
      Frag FixBot
Ziellinie
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 83
Insgesamt: 1,557
