1. Flip your bike so the seat and handlebars are on the ground.
    • Flip your bike so the seat and handlebars are on the ground.
  2. Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Tighten brake strap using screwdriver and 10mm socket wrench. Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • Tighten brake strap using screwdriver and 10mm socket wrench. Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
  5. Center the wheel and pull back to tighten the chain
    • Center the wheel and pull back to tighten the chain
  6. With wheel pulled back, tighten the two axle nuts using the 15mm socket wrench. Tighten the non-drive side (side without the chain) first.
    • With wheel pulled back, tighten the two axle nuts using the 15mm socket wrench. Tighten the non-drive side (side without the chain) first.
    • Wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Erin Heimburge
30 Reputation
1 Anleitung geschrieben
UC Santa Barbara, Team 2-1, Bradley Spring 2013 Mitglied von UC Santa Barbara, Team 2-1, Bradley Spring 2013
UCSB-BRADLEY-S13S2G1
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 4
Letzte 7 Tage: 28
Letzte 30 Tage: 119
Insgesamt: 5,786
