Zum Hauptinhalt wechseln
Cruiser Bike Rear Wheel Replacement
Was du brauchst
  1. Cruiser Bike Rear Wheel Replacement, Rear Wheel: Schritt 1, Bild 1 von 1
    • Flip your bike so the seat and handlebars are on the ground.
    • This will make it easier to access tire.
  2. Cruiser Bike Rear Wheel Replacement: Schritt 2, Bild 1 von 1
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel.
    • Handle the chain carefully to ensure a successful tire replacement.
  3. Cruiser Bike Rear Wheel Replacement: Schritt 3, Bild 1 von 1
    • Tighten brake strap using screwdriver and 10 mm socket wrench.
    • Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • You will know the socket wrench is has finished tightening when you feel resistance.
  4. Cruiser Bike Rear Wheel Replacement: Schritt 4, Bild 1 von 1
    • Center the wheel and pull back to tighten the chain.
    • If the bike wheel is unusable use tire levers to remove tire.
  5. Cruiser Bike Rear Wheel Replacement: Schritt 5, Bild 1 von 1
    • With the wheel pulled back, tighten the two axle nuts using the 15 mm socket wrench.
    • Tighten the non-drive side (side without the chain) first.
    • The wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
    • Use a tire pump to make sure the tire is full of air and ready to ride.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UC Santa Barbara, Team 2-1, Bradley Spring 2013 Mitglied von UC Santa Barbara, Team 2-1, Bradley Spring 2013
UCSB-BRADLEY-S13S2G1
4 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 48
Insgesamt: 10,932
