Zum Hauptinhalt wechseln
Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement
Was du brauchst
  1. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement, Recoil Starter: Schritt 1, Bild 1 von 1
    • Remove the four screws from the hood of the lawnmower using a Phillips #0 screwdriver.
  2. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 2, Bild 1 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 2, Bild 2 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 2, Bild 3 von 3
    • Remove the hood of the lawnmower by pulling up.
  3. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 3, Bild 1 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 3, Bild 2 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 3, Bild 3 von 3
    • Using a wrench, remove the three nuts from the lawnmower’s defective recoil starter.
  4. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 4, Bild 1 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 4, Bild 2 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 4, Bild 3 von 3
    • Remove the defective recoil starter by pulling up.
  5. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 5, Bild 1 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 5, Bild 2 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 5, Bild 3 von 3
    • Place the new recoil starter in the lawnmower where the defective one was prior.
  6. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 6, Bild 1 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 6, Bild 2 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 6, Bild 3 von 3
    • Tighten the new recoil starter onto the lawnmower with a wrench and the nuts you had removed earlier.
  7. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 7, Bild 1 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 7, Bild 2 von 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: Schritt 7, Bild 3 von 3
    • Tighten the hood back onto the lawnmower with a Phillips #0 screwdriver and the four screws you had removed previously.
    • Make sure not to screw the hood on too tightly.
Ziellinie
Andres Dominguez
145 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team Z-69, Briggs Spring 2022 Mitglied von CSU Los Angeles, Team Z-69, Briggs Spring 2022
CSULA-BRIGGS-S22SZG69
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 18
Letzte 30 Tage: 79
Insgesamt: 1,884
