Zum Hauptinhalt wechseln
Cuisinart CPB-380 Motor Replacement
Was du brauchst
  1. Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: Schritt 1, Bild 1 von 3 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: Schritt 1, Bild 2 von 3 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: Schritt 1, Bild 3 von 3
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Motor Replacement: Schritt 2, Bild 1 von 2 Cuisinart CPB-380 Motor Replacement: Schritt 2, Bild 2 von 2
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Motor Replacement: Schritt 3, Bild 1 von 3 Cuisinart CPB-380 Motor Replacement: Schritt 3, Bild 2 von 3 Cuisinart CPB-380 Motor Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Motor Replacement: Schritt 4, Bild 1 von 3 Cuisinart CPB-380 Motor Replacement: Schritt 4, Bild 2 von 3 Cuisinart CPB-380 Motor Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Motor Replacement: Schritt 5, Bild 1 von 2 Cuisinart CPB-380 Motor Replacement: Schritt 5, Bild 2 von 2
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Motor Replacement, Motor: Schritt 6, Bild 1 von 2 Cuisinart CPB-380 Motor Replacement, Motor: Schritt 6, Bild 2 von 2
    • Remove the four 13mm screws holding down the frame located at the bottom of the inverted blender using the Phillips #2 screwdriver.
    • Remove frame.
  7. Cuisinart CPB-380 Motor Replacement: Schritt 7, Bild 1 von 2 Cuisinart CPB-380 Motor Replacement: Schritt 7, Bild 2 von 2
    • Grab the motor by the black gear and the white filter.
    • Unscrew the black gear.
  8. Cuisinart CPB-380 Motor Replacement: Schritt 8, Bild 1 von 3 Cuisinart CPB-380 Motor Replacement: Schritt 8, Bild 2 von 3 Cuisinart CPB-380 Motor Replacement: Schritt 8, Bild 3 von 3
    • With the metal spudger remove the four rubber stoppers.
    • Remove the four 13mm screws with the Phillips #2 screwdriver.
  9. Cuisinart CPB-380 Motor Replacement: Schritt 9, Bild 1 von 1
    • Separate the top from the motor.
    • Pinch perpendicular to the flat surface and pull out the blue wire.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
What is the part number and price for Cuisinart CPB-380 Motor?
Paul Hagen - Antwort
What is the part number and price for Cuisinart CBD-380 motor and price....
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 15
Letzten 30 Tage: 48
Insgesamt: 2,380
