Einleitung
Did you drop the toaster and broke the cover? This guide will explain how to replace outer case of Cuisinart CPT-140BK toaster. This guide can also be used to get to other components inside the toaster.
Was du brauchst
Flip the toaster over so the bottom is facing up.
Unscrew all 4mm screws in the base using Phillips #2 screwdriver.
Take off the lever knobs by pulling it away from the toaster.
Disconnect the cables that connects the toaster to the circuit board in both panels.
Place the toaster right side up.
Carefully lift up the top cover from the interior of the toaster.
