Einleitung
This guide will show you how to replace the display and will require soldering.
Was du brauchst
Open the lid of the coffee pot.
Remove the two 1.6mm Phillips #1 screws from inside of the lid.
Slide the display into the coffee maker so that way you can access the screws in the back.
Remove the four 1mm Phillips #0 screws from the back of the display.
Remove the back panel from the display.
Remove the 1mm Phillips #0 screw from the motherboard.
2 weitere Personen haben diese Anleitung absolviert.
