Zum Hauptinhalt wechseln
Cuisinart DCC-1100 Drip Spring Replacement
Was du brauchst
  1. Cuisinart DCC-1100 Drip Spring Replacement, Drip Spring: Schritt 1, Bild 1 von 1
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Drip Spring Replacement: Schritt 2, Bild 1 von 1
    • Remove the coffee pot and open the top lid.
  3. Cuisinart DCC-1100 Drip Spring Replacement: Schritt 3, Bild 1 von 2 Cuisinart DCC-1100 Drip Spring Replacement: Schritt 3, Bild 2 von 2
    • Remove the basket filter holder.
  4. Cuisinart DCC-1100 Drip Spring Replacement: Schritt 4, Bild 1 von 1
    • Remove the basket filter from the holder.
  5. Cuisinart DCC-1100 Drip Spring Replacement: Schritt 5, Bild 1 von 1
    • Press up on the drip spring mechanism.
  6. Cuisinart DCC-1100 Drip Spring Replacement: Schritt 6, Bild 1 von 2 Cuisinart DCC-1100 Drip Spring Replacement: Schritt 6, Bild 2 von 2
    • While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
  7. Cuisinart DCC-1100 Drip Spring Replacement: Schritt 7, Bild 1 von 1
    • Remove the spring from the dripper.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Josh Harvey
889 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S20-G4, Passmore Spring 2018 Mitglied von USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
Where do you find replacement springs?
Mrich - Antwort
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
Chris Rockett -
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
Raymond Classen - Antwort
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
ncrenshaw4 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 17
Letzte 30 Tage: 53
Insgesamt: 11,627
