Einleitung
In this guide you will learn how to replace the Cuisinart DCC-1100 Heating Element if you are having issues with the device heating up. Please have a replacement heating element ready and potentially extra thermal paste. Also unplug the machine before beginning work.
Was du brauchst
Remove the coffee pot and unplug the maker.
Flip the coffee maker over so that way the bottom is facing you.
Remove the five 1.6mm Phillips #1 screws from the bottom.
Remove the bottom cover.
Remove the two 1.6mm Phillips #0 screws from the heating element.
Lift up the heating element and remove the hot plate.
Disconnect the heating element.
Pinch the tube clips and remove from tubes from the heating element.
3 weitere Personen haben diese Anleitung absolviert.
