Einleitung
This guide will help you replace the hot plate of the Cuisinart DCC-1100. Please have a replacement hot plate ready for the installation and unplug the machine before beginning work.
Was du brauchst
Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
4 weitere Personen haben diese Anleitung absolviert.
13 Kommentare
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Yes, where do you buy the part??
