Einleitung
This guide will help you with replacing the power cord if your device is not receiving power.
The replacement will require a soldering iron.
  1. Unplug the maker, remove the coffee pot, and flip upside down.
    • Unplug the maker, remove the coffee pot, and flip upside down.
  2. Remove the five 1.6mm Phillips #1 screws from the bottom panel.
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
    • Remove the bottom panel.
    • Push the power cord inward and away from the plastic protection plate.
    • Remove the two 1.4mm Phillips #0 screws from the plastic protection plate.
    • Remove the plastic protection plate.
    • Remove the two 1.6mm Phillips #1 screws from the heating element.
    • Using a flathead screwdriver to remove the outer clips holding the heating unit in place.
    • Flip the heating element up to allow access to the circuit board.
    • Pull out the circuit board and rest it on the side of the machine.
    • Desolder the power cable from the motherboard.
Abschluss
Nicholas Eales
Mitglied seit 25.01.2018
233 Reputation
1 Anleitung geschrieben
USF Tampa, Team S20-G4, Passmore Spring 2018 Mitglied von USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Mitglieder
7 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 78
