Zum Hauptinhalt wechseln
Cuisinart DCC-3200 Hot Plate Replacement
Was du brauchst
  1. Cuisinart DCC-3200 Hot Plate Replacement, Hot Plate: Schritt 1, Bild 1 von 1
    • Unplug the device and flip it over so the bottom is facing upwards.
    • Remove the four screws.
    • Remove the bottom panel.
  2. Cuisinart DCC-3200 Hot Plate Replacement: Schritt 2, Bild 1 von 1
    • Remove the two screws from the silver brace.
  3. Cuisinart DCC-3200 Hot Plate Replacement: Schritt 3, Bild 1 von 2 Cuisinart DCC-3200 Hot Plate Replacement: Schritt 3, Bild 2 von 2
    • Use a spudger to wedge the red tube off of the metal.
    • Repeat this for the other side of the silver pipe deeper in the device.
  4. Cuisinart DCC-3200 Hot Plate Replacement: Schritt 4, Bild 1 von 1
    • Pick up the middle pipe and slide the hot plate out of its area.
    • Apply new thermal paste to the hot plate.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Hamad Khan
385 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 8-3, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-3, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G3
3 Mitglieder
5 Kommentare
Where can one purchase the burner plate?
john Vet - Antwort
Same question as John Vet
Bob Stimson - Antwort
Did anyone ever get a response as to where a replacement could be purchased?
Joe Lubrant -
Did response provide required info?
Joe Lubrant - Antwort
Same question: where can we purchase the burner plate?
Cresny - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 24
Letzte 30 Tage: 104
Insgesamt: 4,851
