Zum Hauptinhalt wechseln
Cuisinart DLC-8F Automatic Circuit Breaker Replacement
Was du brauchst
  1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: Schritt 1, Bild 1 von 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: Schritt 1, Bild 2 von 2
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 2, Bild 1 von 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 2, Bild 2 von 2
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 62 mm Phillips #2 screws from the cable retaining clip.
  4. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 4, Bild 1 von 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 4, Bild 2 von 2
    • Lift off the cable retaining
  5. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 5, Bild 1 von 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 5, Bild 2 von 2
    • Pull apart the two wires of the power cable at their connections as shown.
  6. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 6, Bild 1 von 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 6, Bild 2 von 2
    • Lift out the cable.
  7. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: Schritt 7, Bild 1 von 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: Schritt 7, Bild 2 von 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: Schritt 7, Bild 3 von 3
    • Pull out the power cable screw stand with your hand.
  8. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 8, Bild 1 von 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 15 mm Phillips #2 screws on the automatic circuit breaker.
  9. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 9, Bild 1 von 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 9, Bild 2 von 2
    • Pull out the automatic circuit breaker with your hand.
  10. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 10, Bild 1 von 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 10, Bild 2 von 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: Schritt 10, Bild 3 von 3
    • Pull off the three wires by grabbing from the base of the wire.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 8-6, Banghart Winter 2017 Mitglied von Cal Poly, Team 8-6, Banghart Winter 2017
CPSU-BANGHART-W17S8G6
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 888
