Einleitung
This guide teaches the user how to replace the power switch assembly in your Cuisinart DLC-8F. The removal of the power switch assembly first requires the removal of the bottom hood and all of this can be done with just a Phillips #2 screwdriver. This is an easy process and should only take about 10 minutes.
Was du brauchst
Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
Pull out the three wires coming out of the power switch assembly by firmly grabbing the base of the wires and pulling.
Pull out the power switch assembly with your hand.
This might take some jiggling and effort.
2 weitere Personen haben diese Anleitung absolviert.
