Einleitung
Cooking surfaces may be heating unevenly because the the plates and heating coils are out of alignment. This guide will take you through the steps to disassemble the device, allowing you to reassemble it correctly.
Was du brauchst
Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
Remove the single 5.5 mm Phillips #2 screw next to center black button.
After removing the center screw the metal plate should be free to remove.
Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
The aligned parts will allow the cooking surfaces to work properly.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
