Einleitung
Use this guide to replace the "Chop" and "Grind" buttons located on the Cuisinart Mini-Prep DLC-2A.
Was du brauchst
Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
Locate the Button Panel inside the blender.
Using your Phillips #1 Screwdriver, remove the two screws which hold the panel in place.
Locate the black box held in place on the panel.
Using your Spudger, wedge the black box out of its place to uncover the button
Once the black box is out of place, use your finger to push out the button.
Now replace the old button with your newly acquired button.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
