Einleitung
This guide will lead you through the process of replacing a dead or dying motor in your Cuisinart Mini-Prep DLC-2A.
Was du brauchst
Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
Remove the three screws that hold the motor to the top case using a Phillips #1 screwdriver.
Pull out the metal piece from the casing.
Pull apart the plastic casing that contains the rod.
Take off the plastic gears.
Use the Phillips #1 screwdriver to take off the screws that hold the white plastic to the metal piece.
Pull apart the white plastic from the metal piece.
Use an electric screwdriver with a Phillips #1 head to take off the top metal piece.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
