Zum Hauptinhalt wechseln
Cuisinart PowerPrep Plus DLC-2014CHB Disassembly
Was du brauchst
  1. Cuisinart PowerPrep Plus DLC-2014CHB Disassembly, Cuisinart PowerPrep Plus DLC-2014CHB: Schritt 1, Bild 1 von 2 Cuisinart PowerPrep Plus DLC-2014CHB Disassembly, Cuisinart PowerPrep Plus DLC-2014CHB: Schritt 1, Bild 2 von 2
    • Remove four 17 mm screws from the bottom panel of the processor with a Phillips #2 screwdriver.
    • Remove the bottom panel from the main food processor chassis.
  2. Cuisinart PowerPrep Plus DLC-2014CHB Disassembly: Schritt 2, Bild 1 von 1
    • Remove three 15 mm screws to free the control panel from the chassis bracket using a Phillips #2 screwdriver.
  3. Cuisinart PowerPrep Plus DLC-2014CHB Disassembly: Schritt 3, Bild 1 von 2 Cuisinart PowerPrep Plus DLC-2014CHB Disassembly: Schritt 3, Bild 2 von 2
    • Remove two 10 mm screws to free the button circuit board from the bracket using a Phillips #2 screwdriver.
    • Remove three 10 mm screws attached to the circuit board to detach from the bracket panel using a Phillips #2 screwdriver.
  4. Cuisinart PowerPrep Plus DLC-2014CHB Disassembly: Schritt 4, Bild 1 von 1
    • Remove two 10 mm screws connecting the weight sensor to the front panel using a Phillips #2 screwdriver.
  5. Cuisinart PowerPrep Plus DLC-2014CHB Disassembly: Schritt 5, Bild 1 von 1
    • This device operates by first detecting the cup through a weight sensor. Then, by pressing pulse, on, or dough, the motor rotates a rod which the blade attachment fits onto.
    • There is an on/off button which turns the various components on, and the lights indicate which modes are active. The motor does not heat up enough for a need for temp regulation.
Abschluss
Justin Liu
171 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 217
