Zum Hauptinhalt wechseln
Cuisinart Smart Stick CSB-75 Power Switch Board Replacement
Was du brauchst
  1. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: Schritt 1, Bild 1 von 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: Schritt 1, Bild 2 von 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: Schritt 1, Bild 3 von 3
    • Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
    • After prying these off, the screws will be exposed.
  2. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 2, Bild 1 von 2 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 2, Bild 2 von 2
    • Remove three 13.3 mm Phillips PH#2 screws.
  3. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 3, Bild 1 von 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 3, Bild 2 von 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 3, Bild 3 von 3
    • Pry open Cuisinart using a plastic opening tool.
    • The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Make sure to pry open near the clips of the smart stick for easy opening.
  4. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 4, Bild 1 von 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 4, Bild 2 von 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the 4 screws on the inside.
    • Remove 2 13.3mm Phillips PH#2 screws.
    • Remove 2 17.5 mm Phillips PH#2 screws.
    • Unscrewing these screws will isolate the switch board.
  5. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 5, Bild 1 von 2 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: Schritt 5, Bild 2 von 2
    • Refer to these steps on Soldering to replace the switch board in the smart stick.
    • Be careful when soldering. Metal components will become very hot.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 16-2, Wollert Fall 2015 Mitglied von USF Tampa, Team 16-2, Wollert Fall 2015
USFT-WOLLERT-F15S16G2
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 81
Insgesamt: 1,572
