Einleitung
This guide will instruct you on replacing the function switch that toggles between the "warm broil","Broil","toast","Bake" and "Bake Air fry" functions.
Was du brauchst
Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
Pull off the back.
Pick the grey stoppers out with a sprudger.
Using a Phillips #1 screwdriver, remove these three 11 mm screws.
Inside of the device locate the function switch and remove the indicated screws (4.97mm).
Rotate function knob to broil so plastic tab is visible. Use screwdriver to push tab down and pull knob out from front side.
Remove 2 screws revealed under the front knob
Eine weitere Person hat diese Anleitung absolviert.
