Einleitung
Are you having issues with your Cuisinart Oven's light not turning on? You may need to replace the light's spring. This guide will show you how to.
Be warned, the light switch has small pieces.
Was du brauchst
Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
Pull off the back.
Pick the grey stoppers out with a sprudger.
Using a Phillips #1 screwdriver, remove these three 11 mm screws.
Fast fertig!
Abschluss
