Einleitung
Are you having issues with your Cuisinart Oven's light not turning on? You may need to replace the light's spring. This guide will show you how to.
Was du brauchst
Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
Pull off the back panel.
Use a spudger to pull out the grey stoppers.
Use a Phillips #1 screwdriver to remove all three 11 mm screws.
Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
Unscrew these two screws to detach the light switch from the panel.
