Einleitung
Are you having trouble with a flickering light bulb in your Cuisinart TOA-60FR? If so, this guide will help you know if you need to replace your lightbulb or find other solutions.
Make sure you set aside a fair amount of time to complete this; even if you replace your lightbulb, it isn't easy without removing the whole outside of the device. The lightbulb illuminates the entire toaster oven; it may appear insignificant, but it is an essential component.
Was du brauchst
Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
Pull off the back panel.
Use a spudger to pull out the grey stoppers.
Use a Phillips #1 screwdriver to remove all three 11 mm screws.
Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
Remove these two 12.8 mm screws at the top on each side.
Remove two 12.8 mm screws at the bottom, as demonstrated in the first picture.
Eine weitere Person hat diese Anleitung absolviert.
