Einleitung
This guide will walk you through the process of gaining access to the device. The Cuisinart toaster oven's components are all contained within the device's inner layer. To get through that, you have to remove the entire outer layer.
Was du brauchst
Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
Pull off the back.
Pick the grey stoppers out with a sprudger.
Using a Phillips #1 screwdriver, remove these three 11 mm screws.
To put the device back together, follow these steps in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
