Einleitung
This guide will walk you through the process of reaching the inside of a Cuisinart toaster oven. The oven's components are contained within this inner layer, and reaching them requires removal of the entire outer layer.
Was du brauchst
Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
Pull off the back panel.
Use a spudger to pull out the grey stoppers.
Use a Phillips #1 screwdriver to remove all three 11 mm screws.
Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
To put the device back together, follow these steps in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
