Einleitung
This disassembly guide will illustrate how to completely disassemble the Cuisinart WMR-CA(CR). This can be a messy process if the device is used. Do not disassemble while plugged in. All screws can be removed with a #2 Phillips head screwdriver.
Was du brauchst
Cuisinart WMR-CR(CA) fully assembled. This is the starting position.
There are five 10 mm black screws holding the plastic plate down. Remove these screws to expose the central wire hub.
Take off the plastic plate to expose the central wire hub on the bottom of the waffle maker.
Remove the central 10 mm gray screw as shown to detach the hub and stainless steel frame from the bottom side heating element.
Additionally, remove the two 10 mm black screws holding down the AC power supply cord.
Remove the two 9 mm gray screws that hold the plastic hub to the frame as shown.
Remove the 25 mm gray screw from the regulating thermostat.
Additionally, remove the 9 mm gray screw holding down the red wire as shown.
Flip over to the top side.
Use a metal spudger, Jimmy, or some other thin pry tool to loosen up the plastic plate on the top side.
Once loosened, pull down and up to remove the plate, exposing the top side frame screw.
Remove the 9 mm gray screw holding the top side frame plate.
This exposes the top side heating element and plate.
Remove the four 9 mm gray screws holding the top side press plates down.
Yes, there are four screws.
Remove the last 9 mm gray screw holding the top side press to the bottom side press.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
