Einleitung
This guide will instruct you on how to properly disassemble your Cuisinart-140BK toaster. It will also help your properly replace the knobs on your toaster, while further preventing any damage to the device.
Was du brauchst
Schritt 1 Circuit Board
Achtung: Die Schritte 1-6 stammen von einer Anleitung, die derzeit bearbeitet wird.
Turn the toaster upside down.
Unscrew all 4mm screws using Phillips #2 screwdriver.
Turn the toaster right side up.
Pull out the toaster lever knobs by pulling it away from the toaster before removing the top cover.
Detach the cable that connects the toaster to the circuit board, in both control panels.
Unscrew total of six 4mm screws that attach each circuit board to the top cover, using Phillips #2 screwdriver.
Remove and replace the circuit board.
This is how the device should look without the knob.
Repeat the process on the opposite side of the toaster to remove the second knob.
