Zum Hauptinhalt wechseln
Curtain Rail Clipper Replacement
Was du brauchst
  1. Curtain Rail Clipper Replacement, Rail Clipper: Schritt 1, Bild 1 von 3 Curtain Rail Clipper Replacement, Rail Clipper: Schritt 1, Bild 2 von 3 Curtain Rail Clipper Replacement, Rail Clipper: Schritt 1, Bild 3 von 3
    • Unhook the curtain hooks and move your curtain aside for working space.
  2. Curtain Rail Clipper Replacement: Schritt 2, Bild 1 von 3 Curtain Rail Clipper Replacement: Schritt 2, Bild 2 von 3 Curtain Rail Clipper Replacement: Schritt 2, Bild 3 von 3
    • Using a Square #0 Screwdriver, unscrew the faulty curtain clipper from the wall in a counter clockwise motion.
  3. Curtain Rail Clipper Replacement: Schritt 3, Bild 1 von 3 Curtain Rail Clipper Replacement: Schritt 3, Bild 2 von 3 Curtain Rail Clipper Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the connecting piece of the curtain clipper using the Square #0 screwdriver.
    • Remove the curtain clipper from the wall and the curtain rail.
  4. Curtain Rail Clipper Replacement: Schritt 4, Bild 1 von 2 Curtain Rail Clipper Replacement: Schritt 4, Bild 2 von 2
    • Position the new curtain clipper directly over the opening the faulty clipper was installed in.
    • Screw in the new curtain clipper using the Square #0 screwdriver and 40 mm square head screw into the wall.
    • Make sure you are screwing the clipper into the preexisting hole in the wall left by the old hangar. If not you may cause damage to your wall and are mounting the clipper incorrectly.
  5. Curtain Rail Clipper Replacement: Schritt 5, Bild 1 von 3 Curtain Rail Clipper Replacement: Schritt 5, Bild 2 von 3 Curtain Rail Clipper Replacement: Schritt 5, Bild 3 von 3
    • Align the connecting piece of the curtain clipper to the clipper as well as the curtain rail.
    • Screw the connecting piece to the clipper and curtain rail until fastened securely using the Square #0 screwdriver and the 4 mm square head screw.
  6. Curtain Rail Clipper Replacement: Schritt 6, Bild 1 von 2 Curtain Rail Clipper Replacement: Schritt 6, Bild 2 von 2
    • Hook the curtain up when the clipper is fastened to ensure it holds firmly.
Abschluss
hakim
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G19, O'Regan Winter 2021 Mitglied von York University, Team S1-G19, O'Regan Winter 2021
YORK-O'REGAN-W21S1G19
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 498
