Zum Hauptinhalt wechseln
Cyber-Shot DSC-H55 Battery Replacement
  1. Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: Schritt 1, Bild 1 von 2 Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: Schritt 1, Bild 2 von 2
    • Before you begin it is important to know where the battery compartment is. The battery compartment is located on the bottom of the camera.
    • Place the camera upside down with the lens facing you so that the battery compartment is facing up.
    • Place your thumb on the lid of the battery compartment making sure you put some pressure.
  2. Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: Schritt 2, Bild 1 von 3 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: Schritt 2, Bild 2 von 3 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: Schritt 2, Bild 3 von 3
    • Grab the camera with one hand, with your thumb still on the lid, apply pressure and slide to the right.
    • Lift the lid, exposing the battery and SD slot.
  3. Cyber-Shot DSC-H55 Battery Replacement, Removing Battery: Schritt 3, Bild 1 von 1
    • There is a small blue tab on the right of the compartment. In order to remove the battery, move this tab aside and the battery will pop up.
  4. Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: Schritt 4, Bild 1 von 2 Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: Schritt 4, Bild 2 von 2
    • Grab the new battery. Place the battery so that the arrow is pointing down and facing you. Next, slide the the battery into the battery compartment.
    • The blue tab will lock the battery into place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jazmin Young
608 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 6-2, Brown Winter 2015 Mitglied von USF Tampa, Team 6-2, Brown Winter 2015
USFT-BROWN-W15S6G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 942
