Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
To remove the disc tray bracket, you must first remove the top panel of the DVD, which exposes the disc tray bracket. The Disc tray bracket sits on top of the disc tray to keep the disc in place while in use.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD. Unplug the DVD player from the wall socket.
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. Remove the top panel of the DVD Player by: Sliding the top panel backwards.
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray. Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
    • Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
  5. Lift up on the bracket by: Sliding the disc tray bracket forward.
    • Lift up on the bracket by:
    • Sliding the disc tray bracket forward.
    • Lifting the back edge up.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Chris Menezes
630 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-5, Forte Spring 2014 Mitglied von Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 14
Letzten 30 Tage: 54
Insgesamt: 3,126
