Zum Hauptinhalt wechseln
CyberPowerPC Fangbook MS-1763 Battery Replacement
Was du brauchst
  1. CyberPowerPC Fangbook MS-1763 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Save all of your work and turn off the laptop before beginning.
    • Close the laptop and flip it so that the bottom side is facing up.
    • Locate the battery compartment.
  2. CyberPowerPC Fangbook MS-1763 Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull the latches away from the battery compartment. The lid of the compartment should pop out of place.
  3. CyberPowerPC Fangbook MS-1763 Battery Replacement: Schritt 3, Bild 1 von 1
    • Tilt the lid so that it leans away from the laptop and exposes the battery below.
    • Remove the battery from the newly opened compartment.
Abschluss
Insert a new battery and close the compartment lid to complete.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
what is the battery name?
Jimmy Grant - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,083
