Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The case of the keyboard is plastic and can break. This guide will show how to replace the case of the keyboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Be sure to unplug the keyboard before starting the disassembly. Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  3. Remove the sixteen 5 mm length screws using the Phillips head #2. One of the screws may be located underneath a manufacturer's sticker.
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  4. Lift up and remove the plastic casing.
    • Lift up and remove the plastic casing.
Abschluss
Braydon Lantz
193 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S15-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 174
