Zum Hauptinhalt wechseln
CyberPowerPC RGB 7 Color USB Outlet Replacement
Was du brauchst
  1. CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: Schritt 1, Bild 1 von 2 CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: Schritt 1, Bild 2 von 2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color USB Outlet Replacement: Schritt 2, Bild 1 von 2 CyberPowerPC RGB 7 Color USB Outlet Replacement: Schritt 2, Bild 2 von 2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color USB Outlet Replacement: Schritt 3, Bild 1 von 1
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color USB Outlet Replacement, LED Backlight: Schritt 4, Bild 1 von 1
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color USB Outlet Replacement: Schritt 5, Bild 1 von 1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color USB Outlet Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the LED board, which should now come free from the casing.
  7. CyberPowerPC RGB 7 Color USB Outlet Replacement, USB Outlet: Schritt 7, Bild 1 von 1
    • Remove the motherboard and its attached cable from the plastic casing. The cord should now be free and can be replaced.
Abschluss
USF Tampa, Team S15-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 641
