Zum Hauptinhalt wechseln
CyberpowerPC Fangbook HX6 Screen Replacement
Was du brauchst
  1. CyberpowerPC Fangbook HX6 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • To replace the screen you will need a screwdriver (a size zero was used in this guide), and a tool that can be used to pry off the screen covering (a spudger was used in this guide).
  2. CyberpowerPC Fangbook HX6 Screen Replacement: Schritt 2, Bild 1 von 3 CyberpowerPC Fangbook HX6 Screen Replacement: Schritt 2, Bild 2 von 3 CyberpowerPC Fangbook HX6 Screen Replacement: Schritt 2, Bild 3 von 3
    • Insert the spudger gently into the seam that connects the front plate to the rest of the device.
    • Move the tool carefully around the screen and apply a small amount of pressure. You are trying to undo several clasps holding the front plate on.
    • Do this on all sides of the face plate except for the bottom. The bottom will have a strip of adhesive you will need to carefully pull off to separate the face plate from the bottom of the screen.
  3. CyberpowerPC Fangbook HX6 Screen Replacement: Schritt 3, Bild 1 von 2 CyberpowerPC Fangbook HX6 Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 4mm silver screws on both sides of the top of the screen.
    • Once you have removed them, gently pull the screen off of the aligning dials (the small plastic pieces to the left of the screws).
  4. CyberpowerPC Fangbook HX6 Screen Replacement: Schritt 4, Bild 1 von 2 CyberpowerPC Fangbook HX6 Screen Replacement: Schritt 4, Bild 2 von 2
    • At this point the only thing keeping the screen attached to the laptop is this small wire and connector shown here.
    • Gently pull the screen out and turn it over so that you can see where the connector is attached.
    • Carefully remove it. Once this is done you have successfully removed the screen from your laptop.
Abschluss
Eric Box
159 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 826
