Einleitung
Use this guide to assist with general disassembly or troubleshooting of your braille display.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the four bottom screws with a Phillips #00 screwdriver. Remove the four bottom screws with a Phillips #00 screwdriver.
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset.
    • Remove the plastic cover, paper and chipset.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the two screws with a Phillips #00 screwdriver on the logic board. take out the main circuit like show in the picture take out the main circuit like show in the picture
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  5. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver.
    • Remove the four screws with a Phillips #00 screwdriver.
  6. Remove the connector delicately. Remove the connector delicately. Remove the connector delicately.
    • Remove the connector delicately.
  7. when you put it back together make sure mechanical cells are connected correctly when you put it back together make sure mechanical cells are connected correctly
    • when you put it back together make sure mechanical cells are connected correctly
Abschluss
Sisyphe
332 Reputation
2 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 505
