Zum Hauptinhalt wechseln
D-Link DCS-2630L Wi-Fi Camera Microphone Replacement
Was du brauchst
  1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Back casing: Schritt 1, Bild 1 von 1
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 3, Bild 1 von 1
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 4, Bild 1 von 1
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Microphone: Schritt 5, Bild 1 von 1
    • Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
  6. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 6, Bild 1 von 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 6, Bild 2 von 2
    • Detach the white plug by gently pulling on the black wires.
  7. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 7, Bild 1 von 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 7, Bild 2 von 2
    • Remove the circuit board to expose the camera body.
    • At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
  8. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 8, Bild 1 von 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 8, Bild 2 von 2
    • Gently pull on the grey wire to detach the microphone from the camera body.
  9. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 9, Bild 1 von 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 9, Bild 2 von 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: Schritt 9, Bild 3 von 3
    • Detach the microphone from the circuit board by gently pulling on the grey wire.
Abschluss
IUPUI, Team S4-G2, Baechle Spring 2018 Mitglied von IUPUI, Team S4-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 373
