Was du brauchst
Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
Detach the speaker wire by gently pulling on the side closest to the body of the camera.
Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
Remove the circuit board to expose the camera body.
At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
Detach the microphone from the circuit board by gently pulling on the grey wire.
