Einleitung
The root of many problems may lie in a faulty motherboard. Since the motherboard is the device’s brain, failure with the motherboard can cause many problems. Here you can find how to replace the motherboard to restore functionality. You will need a #1 Phillips head screwdriver, a pair of blunt ended tweezers, and a soldering iron.
Was du brauchst
Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
Using your hands, open the camera body by wiggling the bottom free from the upper shell.
Disconnect the five quick connections attaching the various cables to the motherboard with your fingers or blunt ended tweezers.
Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
Using a #1 Phillips screwdriver, remove the single 7mm screw holding the motherboard in place.
Wiggle free the motherboard from the bottom of the body.
There are two pegs that limit the motherboard's rotation. Have some patience when wiggling it free.
The power and ethernet ports have ledges along their top surface. These must be removed from the body at an angle relative to the horizontal.
