Einleitung
If you find you need to replace the Wi-Fi antenna, follow this guide. Since the antenna is required to connect wirelessly to the camera, replacing the antenna may allow you to reclaim this function. The antenna has a cover that connects to the body, as well as a single wire soldered to the motherboard. A small Phillips head screwdriver and a soldering iron will be needed.
Was du brauchst
Locate and remove the four rubber feet on the bottom of the camera using your fingers or a pair of tweezers.
Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
Using your hands, open the camera body by wiggling the bottom free from the upper shell.
Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
Pinch the WiFi antenna's clip mount inside the upper part of the body with blunt ended tweezers while pulling the antenna from the outside.
