Einleitung
There are times that the antenna of the Wi-Fi Baby Camera does not work. This is a step by step guide on how to remove a faulty antenna from the Wi-Fi Baby Camera and replacing it with a working antenna.
Was du brauchst
Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
There will be a light yellow rubber stopper that is holding the antenna in place.
With your tweezers, gently tug on the stopper to make it come out, or at least come loose.
If the stopper does not completely come out, use the round top of the antenna to push down on it.
Once the rubber stopper has been pushed out, you will now be able to easily pull the antenna out from the back casing.
