Einleitung
The heat sink is responsible for regulating the heat flow and temperature control in your device. If your device is overheating and not cooling itself down properly, then the heat sink will need to be replaced. Follow this guide for the steps on how to replace the heat sink.
Was du brauchst
Wedge the opening tool between the red top panel and the gray bottom panel.
Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
Unscrew the two 7mm screws with a Phillips #1 screwdriver.
Lift the heat sink off the metal plate with your fingers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
