Zum Hauptinhalt wechseln
D-Link EBR-2310 LED Light Replacement
Was du brauchst
  1. D-Link EBR-2310 LED Light Replacement, Remove Plastic Screw Coverings: Schritt 1, Bild 1 von 1
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 LED Light Replacement, Remove Screws: Schritt 2, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 LED Light Replacement, Pry Open The Router: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: Schritt 4, Bild 1 von 2 D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: Schritt 4, Bild 2 von 2
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: Schritt 5, Bild 1 von 2 D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: Schritt 5, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 LED Light Replacement, Remove Bottom Case: Schritt 6, Bild 1 von 1
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
  7. D-Link EBR-2310 LED Light Replacement, Locate Problematic LED light: Schritt 7, Bild 1 von 1
    • Locate the problematic LED light on the motherboard.
    • Using a plastic opening tool, very gently tilt its black base backwards.
  8. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: Schritt 8, Bild 1 von 2 D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: Schritt 8, Bild 2 von 2
    • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
  9. D-Link EBR-2310 LED Light Replacement, Remove the LED Light: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
  10. D-Link EBR-2310 LED Light Replacement, Complete Removal: Schritt 10, Bild 1 von 1
    • You should now have a removed LED light, ready to be replaced with a new one.
Abschluss
Jessica
428 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014
USFSM-STEWART-F14S1G4
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 391
