Zum Hauptinhalt wechseln
D-link PowerLine Hard Reset
Was du brauchst
  1. D-link PowerLine Hard Reset, D-link PowerLine Hard Reset: Schritt 1, Bild 1 von 1
    • (With router unpluged, and no ethernet cable attched) Turn the router on (push in the power button on the side) remember it's not plugged into the wall yet.
  2. D-link PowerLine Hard Reset: Schritt 2, Bild 1 von 1
    • Take a pin or micro screwdriver and push in and hold the reset button.
    • Still holding the reset button plug the router into a power outlet.
    • Keep holding down the reset button for at least 15 seconds.
    • If you have the same luck I did your green lights on the side will start to cycle and light up.
    • Now you can go back to your quick install guide that came with the router and set it up again.
Abschluss
hope it works for you
4 weitere Nutzer:innen haben diese Anleitung absolviert.
alan
1 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 5,933
