Zum Hauptinhalt wechseln
DBPOWER RD-810 Lens Replacement
Was du brauchst
  1. DBPOWER RD-810 Lens Replacement, Top Cover: Schritt 1, Bild 1 von 2 DBPOWER RD-810 Lens Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Lens Replacement: Schritt 2, Bild 1 von 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: Schritt 3, Bild 1 von 3 DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: Schritt 3, Bild 2 von 3 DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: Schritt 3, Bild 3 von 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Lens Replacement: Schritt 4, Bild 1 von 3 DBPOWER RD-810 Lens Replacement: Schritt 4, Bild 2 von 3 DBPOWER RD-810 Lens Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Lens Replacement: Schritt 5, Bild 1 von 3 DBPOWER RD-810 Lens Replacement: Schritt 5, Bild 2 von 3 DBPOWER RD-810 Lens Replacement: Schritt 5, Bild 3 von 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Lens Replacement, Power Supply Circuit: Schritt 6, Bild 1 von 3 DBPOWER RD-810 Lens Replacement, Power Supply Circuit: Schritt 6, Bild 2 von 3 DBPOWER RD-810 Lens Replacement, Power Supply Circuit: Schritt 6, Bild 3 von 3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Lens Replacement: Schritt 7, Bild 1 von 2 DBPOWER RD-810 Lens Replacement: Schritt 7, Bild 2 von 2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Lens Replacement, Lens: Schritt 8, Bild 1 von 3 DBPOWER RD-810 Lens Replacement, Lens: Schritt 8, Bild 2 von 3 DBPOWER RD-810 Lens Replacement, Lens: Schritt 8, Bild 3 von 3
    • Flip the projector over and remove the two 6mm PH2 phillips head screws.
    • Flip the projector over so that the opening is facing up.
    • Lift the lens up slightly and then move it towards the interior of the projector before lifting it up and out of the way.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
John Russell
914 Reputation
9 Anleitungen geschrieben
USF Tampa, Team S5-G3, Eyestone Spring 2018 Mitglied von USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 488
