Einleitung
Taking out the fan is quick and easy. When removing the fan it is okay to use some force as it's not delicate.
Was du brauchst
Remove the four (9 mm) screws with a PH2 screwdriver.
Remove the two (7 mm) located with a PH2 screwdriver.
Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
Remove the five screws securing the black plastic cover with a J0 screwdriver.
Lift up and out to remove.
7 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Any idea of the specifications of the fan? 12v, 24v? I want to change it for another more quiet… but not sure about its voltage. It is 50x50x20mm right? Thanks!
Hola! También querria sustituirlo por otro más silencioso. ¿Alguna idea de sus especificaciones?
