Einleitung
Follow the remaining steps in this guide in order to locate and replace the speakers locate on the interior bottom of the device housing. Take care not to confuse the speakers with batteries, as they look similar.
Ersatzteile
Keine Ersatzteile angegeben.
Remove the four (9 mm) screws with a PH2 screwdriver.
Remove the two (7 mm) located with a PH2 screwdriver.
Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
Remove the five screws securing the black plastic cover with a J0 screwdriver.
Lift up and out to remove.
Remove the two (3 mm) screws connecting the bracket down and pull out the reflector, using a J0 Philips Head Screwdriver.
Slide out the power source and disconnect its cables from the power jack and the light.
Remove the screws holding down the first speaker with a J0 screwdriver.
Remove the screws holding down the second speaker down.
2 weitere Nutzer haben diese Anleitung absolviert.
