Zum Hauptinhalt wechseln
DJI Mavic Mini Motherboard Replacement
Was du brauchst
  1. DJI Mavic Mini Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 DJI Mavic Mini Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Orient the DJI Mavic Mini so that the camera faces away.
    • Use your finger to depress the lip on the panel until the lid becomes ajar.
    • Flip the panel up to expose the battery module.
  2. DJI Mavic Mini Motherboard Replacement: Schritt 2, Bild 1 von 2 DJI Mavic Mini Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Depress the locking mechanism on the battery module to release the lock.
    • Pull the battery straight out of the casing.
  3. DJI Mavic Mini Motherboard Replacement: Schritt 3, Bild 1 von 2 DJI Mavic Mini Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
    • Check the pin receptacles on the battery module for blockages.
    • Insert a new battery into the casing. Ensure that all connections are clean, unobstructed, and straight.
  4. DJI Mavic Mini Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 DJI Mavic Mini Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 DJI Mavic Mini Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Remove the four 5 mm screws that hold the upper panel using using the J000 screwdriver.
    • Orient the back of the DJI Mavic Mini towards you. Open the battery hatch using the iFixit opening tool to pry open the top panel at the seams.
    • Remove the two 5 mm screws that hold the bottom panel using using the J000 screwdriver.
  5. DJI Mavic Mini Motherboard Replacement: Schritt 5, Bild 1 von 2 DJI Mavic Mini Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Orient the bottom of the DJI Mavic Mini towards you.
    • Remove the bottom panel by inserting the iFixit Opening Tool into the edge of the bottom case.
    • Insert multiple picks in the seam around the perimeter to prevent the bottom panel from closing back up, then pry it open.
  6. DJI Mavic Mini Motherboard Replacement: Schritt 6, Bild 1 von 3 DJI Mavic Mini Motherboard Replacement: Schritt 6, Bild 2 von 3 DJI Mavic Mini Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Remove three 5 mm screws using the J000 screwdriver.
    • Remove the radiator to reveal the main board.
  7. DJI Mavic Mini Motherboard Replacement: Schritt 7, Bild 1 von 3 DJI Mavic Mini Motherboard Replacement: Schritt 7, Bild 2 von 3 DJI Mavic Mini Motherboard Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • When removing the motherboard, don't wipe any thermal paste off of it. This will cause the drone to overheat.
    • Using the ESD Safe Blunt NoseTweezers, carefully remove the glue that holds the cable connectors to the main board, ensuring that you do not scratch the main board. Detach the connectors.
  8. DJI Mavic Mini Motherboard Replacement: Schritt 8, Bild 1 von 3 DJI Mavic Mini Motherboard Replacement: Schritt 8, Bild 2 von 3 DJI Mavic Mini Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the remaining cables and antennas from the main board by prying them up using the ESD Safe Blunt Nose Tweezers.
    • Using the J000 screwdriver, remove the remaining two 5 mm screws that are holding the motherboard down.
    • Remove the motherboard from the DJI Mavic Mini.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Logan Wake
184 Reputation
1 Anleitung geschrieben
Clemson, Team 1-2, Hunter Spring 2022 Mitglied von Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 55
Insgesamt: 3,533
