Zum Hauptinhalt wechseln
DJI Mavic Mini Propellers Replacement
Was du brauchst
  1. DJI Mavic Mini Propellers Replacement, Propellers: Schritt 1, Bild 1 von 3 DJI Mavic Mini Propellers Replacement, Propellers: Schritt 1, Bild 2 von 3 DJI Mavic Mini Propellers Replacement, Propellers: Schritt 1, Bild 3 von 3
    • Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
    • For ease of access place the prop arms in the "open" position.
  2. DJI Mavic Mini Propellers Replacement: Schritt 2, Bild 1 von 3 DJI Mavic Mini Propellers Replacement: Schritt 2, Bild 2 von 3 DJI Mavic Mini Propellers Replacement: Schritt 2, Bild 3 von 3
    • Remove the 2.4 mm J000 screw from the damaged propeller.
    • When removing the screws, you may need to apply some pressure to the swivel mount that holds the propellers.
    • Remove the damaged propellers.
  3. DJI Mavic Mini Propellers Replacement: Schritt 3, Bild 1 von 2 DJI Mavic Mini Propellers Replacement: Schritt 3, Bild 2 von 2
    • Keep the 2.4 mm J000 screw from the damaged propeller to use again when fastening on the replacement.
    • While one or both propellers are removed for replacement, it is recommended that you inspect the exposed swivel mount for any debris which may impact drone performance.
    • Additionally, when fastening the replacement propeller make sure that the screw is inserted into the interior hole on the swivel mount.
Abschluss
Chase Smith
147 Reputation
1 Anleitung geschrieben
Clemson, Team 1-2, Hunter Spring 2022 Mitglied von Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 29
Insgesamt: 872
