Zum Hauptinhalt wechseln
DJI Mavic Pro GPS Module Replacement
Was du brauchst
  1. DJI Mavic Pro GPS Module Replacement, Battery: Schritt 1, Bild 1 von 3 DJI Mavic Pro GPS Module Replacement, Battery: Schritt 1, Bild 2 von 3 DJI Mavic Pro GPS Module Replacement, Battery: Schritt 1, Bild 3 von 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro GPS Module Replacement, Upper Shell: Schritt 2, Bild 1 von 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro GPS Module Replacement: Schritt 3, Bild 1 von 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro GPS Module Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro GPS Module Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
  6. DJI Mavic Pro GPS Module Replacement: Schritt 6, Bild 1 von 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro GPS Module Replacement: Schritt 7, Bild 1 von 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro GPS Module Replacement, GPS Module: Schritt 8, Bild 1 von 1
    • Flip the upper shell over so the metallic plate is facing up.
    • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
    • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
  9. DJI Mavic Pro GPS Module Replacement: Schritt 9, Bild 1 von 1
    • Pry the metallic plate up from the upper shell by using a nylon spudger.
    • Remove the metallic plate from the upper shell by lifting the plate up and out.
    • You may hear a popping sound when prying the metallic plate, but no damage will occur.
  10. DJI Mavic Pro GPS Module Replacement: Schritt 10, Bild 1 von 1
    • Use tweezers to remove the GPS Module from the upper shell.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Kyle Kelser
610 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G3, White Fall 2018 Mitglied von Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 55
Insgesamt: 9,365
